piston XU9JA and XU9J1 and XU9JAZ
Hroche
Hallo boys,
What is the difference between XU9JA piston and piston XU9J1 and XU9JAZ?
Have you a photo of the piston XU9JA and XU9JAZ?
Thanks boys!
Thanks boys!
- Para
- Posiadany PUG: najlepszy
- Numer Gadu-gadu: 1559591
Re: piston XU9JA and XU9J1 and XU9JAZ
Hi Hroche,
I'm not sure is there any difference between those 2, the best would be to measure them and check.
This is standard XU9JA - D6B piston.
Check this out:
http://www.motorenteile.mahle.com/eLIZA ... e/byParams
Link may not work (cookies). In that case, check the mahle site -you'll find differences in their cataloque.
Hroche
do you have a photo of the combustion chamber in the piston?
XU9JAZ
This is piston from XU9JA:
Hroche
I found this photo with D6B (XU9JA)engine. What is correct?
Engine identification (D6b) is on the engine label
Ostatnio zmieniony 29 lis wt, 2011 2:17 pm przez Hroche, łącznie zmieniany 2 razy.
Może ktoś przetłumaczy bo ja pewnie namieszam
Tłoki z XU9JAZ są bardziej wklęsłe bo ten silnik mam mniejszy stopień sprężania. Te na foto u góry( w silniku) to na bank są tłoki z XU9JAZ, takie same mam u siebie
Hroche
photo is from http://www.club205gti.fr/forum09/index.phpHroche pisze:I found this photo with D6B (XU9JA)engine. What is correct?
- pawel
- Posiadany PUG: 1.9 GTI
On the photo You have piston XU9JAZHroche pisze:photo is from http://www.club205gti.fr/forum09/index.phpHroche pisze:I found this photo with D6B (XU9JA)engine. What is correct?
P205
Hroche
I have other photo with D6B engine and pistons are identical
Here:
Here:
Hmm... This is piston from XU9JA from Kaktus's gallery
http://gti.peugeot205.pl/gallery/main.p ... temId=8859
EDIT: Kamkiler have pistons from XU9JAZ(DKZ): http://www.kamkiler.205.pl/
EDIT2: XU9JAZ(DKZ) have Compression Ratio 9.2:1 but XU9JA(D6B) have: 9.6:1 with the same cylinder head so pistons in XU9JAZ(DKZ) must be deeper
